ArthurEld
Solar Wizard
If what you are saying is true, wouldn't that mean that the Solark 12K is the same as the Solark 8K?So I acquired a new DEYE 7.6kw awhile back and will be doing a direct comparison with the Sol-Ark 12k, which is a comparable unit since the Sol-Ark 12k isn't really 12kw on the AC side. It will overload at 7.2 to 7.4KW AC. This is even if the solar/battery side is prducing less than 7.2 KW and the grid is making up the balance. Only 7.2KW AC can be run through the unit. When I first discovered this I thought it was a defective machine until tech support walked me through the fine print. My test will be trying to trip the DEYE and see if it trips at the same load as the Sol-Ark.
