If the first thing that is connected in a system is the MPPT Controller and then the panels and then the load i.e. Inverter, etc, etc. Once you connect the Controller enter all the info for your battery type and then connect everything else up, all working fine. If I put a battery disconnect switch in the system to disconnect for periods of time when I am away for a few days, How does one connect it all back so the the controller is first again. In other words just turning the switch back on at a later date will energize the whole system and not the controller first?
