ianganderton
Auckland, NZ
Just wondering what use cases for direct solar power work well?
Many applications require a battery to be part of the system so power can be delivered when needed.
What doesn’t require a battery in the system?
I guess battery charging is a good use case for direct solar power.
Heating hot water (either directly using say vacuum tubes or PV) for storage in a tank (a different type of battery!)
What else works well using direct solar power with no battery?
