Thanks very much. I believe I'll see less than 50A in level ground. My max speed is about 12mph. Based on your 225 max with a much bigger motor, and other posts I've seen, I suspect max of 150A-180A or so for me. I saw a post with a clamp meter, Kauweets HT206D that showed max DC amps. They are $40 and a useful addition to my tool kit, so I ordered one from Amazon. Previously I couldn't tell from the description & manual if it would hold max amp value. Meter should arrive tonight, so I'll put it on the cart and run it uphill fully loaded and see what the max is. I was going to set up a 30A bms and have it trigger a solenoid for the power output of the battery bank. That is, charge through the bms and have bms shut off the solenoid at 2.5V for protection. But the 300A JDS smart bms is cheap enough to just spring for that and the app eliminates the need for a separate meter. I used to charge every other day just putzing around yard chores. Eliminating the resister coils has really helped. The LIFEPO4 batteries would complete the transformation.....
