BobCollins
Outside of this forum's geeks, I don't see anyone talking of precharging their inverter input. Even here, the discussion rarely extends beyond using a resistor before attaching the last power lead to the inverter. This, of course, ignores the times they disconnect and reattach the battery-to-inverter circuit in some other way, with a circuit breaker, disconnect switch, etc.
Here, the most convenient answer is that they never disconnect the battery. Happy for you, but I doubt this is the general case.
What I suspect is that the general case is many (most) users either ignore or don't see the spark when connecting the battery, and that the switch, etc. is suffering the arc and degrading.
This would beg the question: how quickly will living with this ignored arc cause a failure? Of course, significance of the abuse depends on the size of the inverter and the construction of the switch.
BTW, I do understand there are automatic precharge circuits, but they appear to be pretty rare. A few BMSs (such as Victron's) include an automatic precharge circuit, but they are hardly the general case. Beyond these, everything else I see is DIY construction. Most interestingly, I have yet to see a builtin precharge circuit in the front end of an inverter, which would be an obvious location.
If avoiding the arc is so important, why isn't there a commercial solution? I have explored the problem space, and a stand-alone design is quite feasible. My suspicion is that living with the arc is such a minor issue for most users that there is no market for a solution.
I am interested in thoughts, particularly if I have missed, or misunderstood, some pertinent aspects of the problem.
Thank you.
***********EDIT************
I didn't note above that my project is a vehicle mounted system, not a large, 48 V system. I didn't realize that this was (or might be) a factor.
Answers below tell me that a (the?) primary reason to precharge is to avoid having the BMS react to the high inrush current from charging the capacitors and shutting the circuit off. This makes sense to me.
What I still don't understand is why it appears that many 12 V systems do not appear to have any provision for precharging. Is there a inverter size under-which precharge is not necessary? I asked on the Victron forum if my planed Phoenix 1200 W inverter needed a precharge, and I was assured that it did.
So, my question still stands.
Thank you.
