For comparison my Victron Quattro 5kVA which has pretty large silkscreen font size (also another set of - and + symbols under the 2/0 cables as well):
That's a nice demonstration. Would be a nice idea if someone would make that into a more user friendly setup that non-technical people could use.. like combining it with a Pro Installer EZ-Mount Dual Bank Control Battery Switch with the bulb and bulb holder mounted somehow with it.@Will Prowse continuing our discussion from the other day, a fine example.
Here’s a better way to precharge that will give you a very good indication of you have a short
Great video, thanks Dexter.@Will Prowse continuing our discussion from the other day, a fine example.
Good point. I can't believe people would reverse polarity a huge inverter. Yikes@Will Prowse continuing our discussion from the other day, a fine example.
It happens. Sometimes people can start a conversation or have something on their mind and before you know it. Boom, reverse polarity.Good point. I can't believe people would reverse polarity a huge inverter. Yikes
Maybe sell a 48V bulb with alligator clips and long leads so people have a easy to purchase solution.
I think it was more not as clear as could be. I posted pic above and the polarity is not as evident on the 6000EX as it is on the 6500EX which has color indication as well as text.I saw some comments here regarding the polarity not being labeled. I'm confused on that, I just went out to check the hook ups on these units and it's clearly printed on the board next to the lug. Batt (Pos+) on the left side and Batt(Neg-) on the right.
Honestly it's extremely careless. For someone to have been paid to install this system, there is no excuse. The terminals are labeled. You're getting paid to do this, take your time and get it right. This is putting the end user in an incredibly difficult situation, I would hope his installer is willing to own their responsibility in this matter and make things right.It is labelled but always better to have it as obvious as reasonably possible in case people are not as diligent in verifying (even though I agree they should be).. the manual does state with a caution to also double check. So this is a serious installer error (who was paid to install it from the original posters comments). Hopefully @dhy4buva can get the installer to correct and verify there is no damage otherwise installer is going to need to replace for free.
15W sorry, left that out.50 ohm, how many watts?
You can buy 1/4 watt 50 ohm resistors and you can buy 100 watt 50 ohm resistors.
One can use some bulbs in series instead of searching for a 48V bulb.I found the same type of bulb Dexter used https://www.amazon.com/Forklift-Bulb-Volt-Watt-BA15d/dp/B0046IJTFE
and interestingly a socket that can easily be mounted as well: https://www.amazon.com/Bayonet-Sock..._bxgy_vft_none_img_sccl_1/132-1464949-5005210
I might actually try this setup. I have the dual bank switch as well since I was going to mount a resistor to the switch but this is much better idea as others have also mentioned above to use a bulb but was more convincing seeing a video of it in action
