At some point, you are going to to need to do maintenance / changes on your system.
If you include the ability to individually breaker protect each parallel battery string, then this allows you easily / safely do changes, as well as re-set the BMS if it / when it trips.
So just as an example arrangement, suppose that you have 4 battle born 100s arranged 2 S 2 P in 24 volt.
Put one of these 80 amp, blue sea 187 breakers in series with each parallel string.
Thermal circuit breakers provide heavy duty circuit protection for 25 to 200 Amp loads when switching and circuit protection are both required.
www.bluesea.com
Those batteries are nominal rated for 100 amp discharge so running them conservatively at ~ 50 amps, and then protecting the string with an 80 amp breaker reduces the risk that some will have a BMS trip and the pack will be operating on just part of a pack for very long.
To re-set a BMS, just flip off the breaker and turn it back on - very simple - anyone can do it safely and remember how to do it, even at night in the middle of no where.
If you want to include a pre-charge circuit - just add another similar / lower amp breaker and a resistor off of one of the battery strings.
I do the exact same thing with AGMs - not to re-set a BMS obviously, but it make working on and starting up a system so convenient. If there are issues, it is easy for a customer to isolate a problem / run on 1/2 power / deal with it later vs ruining their vacation.
I do this all of the time.
It is a massive gain in convenience for a small cost of a few more parts.
