1440 watts, as I understand from the instructions, this is what can go to charge the battery, multiply 24 volts by 60 amperes, we get 1440 watts
in the same instructions it says that the maximum power of solar panels can be 1600 watts
but in the same place, the instructions say that the voltage of the solar panels is 30-95 maximum 100 volts and the current from the solar panels is a maximum of 40 amperes, if you take my solar panels 595 watts with characteristics of 34.5 volts, 17.25 amperes according to the 2s2p scheme, you get 69 volts and 34.5 amps, which fits into the specifications
I think that there can be 2380 watts of solar panels at the input, this does not exceed the specifications, but the maximum use will be 1600 watts per load or 1440 watts per battery charge
so far I have only 2 solar panels of 595 watts each, but I want to buy two more, if I can’t connect to the inverter, then I’ll connect it to the mppt controller, though my new battery will be only 140 amps, I’ll have to lower the charging current in the inverter to minimum
I hope you understand something
