Does anyone else have one of these?
I'm new to solar, but so far I'm pretty happy with this. My two big complaints.........the documentation is very inadequate. I was expecting a pretty comprehensive manual, but all I got was about 8 pages of usable content. Only some of the features are explained so a lot of guessing so far.
The other I problem I have is: Sometime after the charging drops below the threshold of 40W (not explained in the manual), charging shuts off. At some point after that, a clicking starts. I have found that the clicking stops when I unplug my solar input cable.
It seems as though as long as there is a load present or cycling (my fridge) it doesn't seem to do it.
So far this is the response I got from the Tech line:
Not impressed with tech support so far.
I have confirmed with the our technical team about the clicking sound in the video for you, it is due to there was not an actual solar input indoors to the unit, but the unit would recognize a connection so this case happened. If you tested the solar charge outdoors, this case and sound would not happen.
