Skinny76
- Jan 17, 2020
- 84
I'm currently looking at the two EG4 6500 AIO inverters and I'm trying to decide which one. The 6000 EX-48HV low frequency version seems like the better of the two, but much heavier and higher idle consumption. It has a 6,000 watt rating with 7,500 solar input capacity. The 6500 EX-48 high frequency has 6,500 watt output rating with 8,000 solar input capacity. Both have a 500 volt VOC input. The low frequency also has split phase capability, but the HF doesn't. I'm seeing both LF and HF as the same price. Is there any reason I would not want the LF? I'm OK with the the weight and slightly higher idle consumption. The input/output isnt enough to affect me for what im doing. Is there something else I should be considering?
I'll have 3x280ah 48 volt batteries connected.
Thanks everyone.
Thanks everyone.
