I'm about to pull the trigger on a 18kpv system through SS, but I have a few questions about wiring. I plan to install the inverter on the opposite side of a wall from my meter and main load (200amp panel)
that is less than 10' from away. I use about 40kWh a day and installing a 13kW pv with 30kW battery backup for night. I plan on a 200amp main breaker under my meter, split the lines with polaris connecters, then to a transfer switch and grid load on inverter. The Load from inverter will go back out the wall to main panel breaker. I live in rural Texas with no permit besides electric co-op approval. (I do want it SAFE) just not bureaucracy safe
1. Should I fight with 4/0 copper or just use 3/0?
2. The manual has about 5 different fuses and breakers the wire goes through that I don't plan to use. Just Grid 200amp disconnect, inverter breakers, then 200amp on Main Panel. I only chose this because the solark 15k manual has no breakers between the grid disconnect and the inverter.
3. The neutral bar on the inverter says if fits 6-gauge wire. This seems small. Is there a way to fit a larger neutral for both the grid and the inverter load.
