I’d like to clarify:
I don’t particularly care how deep the level of settings is via the app. I appreciate having an app, and it’s much better than having to be at the inverter, but, I’ll be making my “big changes” via the web interface.
I see no reason from a technological perspective that an end user such as myself, couldn’t look at the EXACT same screen as your technicians. Thus eliminating any further development or changes required on your end.
For example, the in house level 1 technician that helped me named Sean clearly had elevated permissions in comparison to me. Someone had to set him up as a user and select his user role. I imagine the “head honcho” over at Signature Solar would be “admin”. That person would grant your technicians a “level 1”, “level 2” or “level 3” permission set, each of which has different levels of access (maybe they’re all the same, I’m making assumptions).
When an end user such as myself registers, or in my case when my account is registered by you guys, clearly I have an “end user” version of access with many things missing.
Here’s the simple solution for everyone involved. On a “request” basis, simply elevate our access level to a higher level enabling the same access as the technicians.
If there are permissions that you feel could legitimately cause a problem, just copy that user permission set from “level 1 technician” to a new role called “advanced homeowner”, then disable whatever we shouldn’t have. You now have a simple solution that can be applied to anyone that requests it.
I imagine this would be a 5 minute process to set up, probably easier than me explaining it on an iPhone in a Costco parking lot. I also expect it would cut down on your customer service workload.
As an additional idea: create preconfigured firmware/settings packages that people can install. IE the “I don’t want to back feed the grid” firmware.
I haven’t got to the point of looking to see if system backups are possible either, but absolutely would be something I’d expect to be a big part of this. Any electronics without a backup are a nightmare waiting to happen.
