Yeah that battery is insanely heavy, I manually set the max charge because if my solar put out the 250 amp and the battery BMS didn’t catch it , I could have a fire. But my closed loop coms did not change mine. also my HZ were set to 50hz so I changed it to 60hz. Yeah P03-LUX is correct. A problem I had, was when I put in the password 00000, I kept clicking the down key at the bottom to change to the next page. That cause my EG4 18KW to default to the main screen. Eventually I figured out that you have to click on the side cursor arrow so it want throw the password out. Was Banging my head for hours on that one.
