It may be suboptimal though compared to giving the proper CT feedback to support optimizing for self consumption. Depends on the export compensation in place. If it is 1:1 net metering with no time of use it will not matter.Yes the other panel will consume excess solar to meet it's demands.
Yea 1:1 with no TOU here...so I don't need to optimize I just would like to make sure the power company isn't screwing me over.It may be suboptimal though compared to giving the proper CT feedback to support optimizing for self consumption. Depends on the export compensation in place. If it is 1:1 net metering with no time of use it will not matter.
If it is very low export compensation or 1:1 with high peak prices then giving the inverter a better shot at being smart will pay off
You don’t need to if you set up Home Assistant to merge it in Grafana. You’ll just maybe spend 20 hours setting it up in the beginning.but I don't know if I want to spend 5 hours a month doing math.
I might have to pass on that one...LOLYou don’t need to if you set up Home Assistant to merge it in Grafana. You’ll just maybe spend 20 hours setting it up in the beginning.
I have yet to add energy monitoring to my Home Assistant. In part because lazy, in part because I look at Grafana for my day job already, I feel slightly better maybe using the shitty web app for inefficiently and jankily monitoring my solar and emporia.I might have to pass on that one...LOL
I do not thankfully.Do you get “taxed” on export? Here they dip 1 cent per kWh, which works out to about 3%.
That's what Home Assistant can do.Could all the super clever programming people on this forum get together and make an unofficial or official forum monitoring platform that can take input from all of the usual suspects and I put it in a glamorous display locally ?
Generally speaking voltage is controlled by the producer, current is controlled by the consumer. In a normal scenario the consumer (the inverter) would control the current based on the resistance it provides to the the producer. An MPPT is a little weird because it is designed to run at a range of voltage, none the less if properly engineered it should never try and pull more current that it is capable of handling. For sanity you want a breaker on the feed line that matches your expected draw/wiring capability. The rules don't change for electricity when it comes from a solar panel. If the consumer draws too much current (short or other fault, like a motor with a bad bearing) a safety should trip and break the connection.My understanding is that you can go over the 30 Amp, the system will limit the import to 30, however.
Just put a 30A breaker on the feed line. Current draw is determined by the load, (the consumer), but it's trivial to limit it with a breaker. If the MPPT blows the breaker it was poorly engineered. AMPS are pulled from the source, Volts are pushed from the source.That's what my hope is and it does make sense, but I've seen a 1.2x limit mentioned before.
I'm just hoping for a confirmation before I go that route. My potential run would be ~33A under perfect condiJust tions.
Nobody is using the same protocols and api. Do you have a wire-frame of some description in mind? I'm not a "pretty" kind of programmer, I'm an engineering kind of programmer... I find the EG4 pages lacking, though it is somewhat better these days. Without the EV's I could almost ignore my system at this point. Yesterday was crappy but my worst ever day was about 35KWH.Could all the super clever programming people on this forum get together and make an unofficial or official forum monitoring platform that can take input from all of the usual suspects and I put it in a glamorous display locally ?
This is the power of open source… just one person needs to do it ?Nobody is using the same protocols and api.
I'll start you with a dead simple one.....increase the data rate to seconds instead of minutes ?Let’s make a new thread. What could be better on the EG4 monitoring site. Also settings and app.
I would love to get more feedback like this from all of you. ?
Set it to time instead soc. And set the time 00:00-23:59I love my 18, but the interface can be a PITA at times. I just connected 6 more Lifepower4 batteries. All 12 batteries were about 53%. I wanted to do a full charge to 100%. I wanted to do it via AC, so it is a smooth, linear charge.
So I set my AC stop at 100%. I needed to set my AC start SOC. On the inverter? Nope. In the app? Nope. On the web based config? Yep.
At least make the app and web the same for God's sake.
You can't poll it that fast. I can't get it to poll reliably faster than about 2-3 seconds. I'll work up another thread for the 18/12 around polling/modbus/UI/monitoring.I'll start you with a dead simple one.....increase the data rate to seconds instead of minutes ?
I got it working, but consistency between app and web page would be betterSet it to time instead soc. And set the time 00:00-23:59
Solar Assistant poll's them every 5 seconds, I would be happy if the web monitor could do it every 30/60 seconds. But, please at least have the inverter update the website when a settings change is made.You can't poll it that fast. I can't get it to poll reliably faster than about 2-3 seconds. I'll work up another thread for the 18/12 around polling/modbus/UI/monitoring.
