ScullerGuy
- Sep 29, 2019
- 4
For my setup I want to operate on solar unless the SOC drops below 20%. At that point I want it to pull from a grid connection to charge the batteries. In the Maintenance Tab, there is a section labeled "AC Charge" where
"AC Charge Based On" can be set for "Battery SOC (According To)"
"AC Charge Start Battery SOC(%)" can be set to 20%
"AC Charge End Battery SOC(%)" can be set for 80%
By doing this will the inverters work as I need, or will they default to Bypass mode over Solar if the Grid Input has current?
