timselectric
- Feb 5, 2022
- 18,637
In Closed loop, the dry contacts are activated by a set SOC %.
In open loop, the dry contacts are activated by voltage.
If charging hard, the surface charge voltage will be higher. So, you will have to adjust for that.
But it's just a matter of fine tuning the settings, like anything else.
The charging amps will be a constant, in this setup. So, it won't be hard to calibrate.
