Adam De Lay
Solar Wizard
Again, all conceptual. I don't even have a chargeverter. Might get one for my generator at some point, but trying to think of additional uses.
Nice! Never thought about that.Another niche benefit i have been thinking about.
Most AIO's have a SCC that is large enough to charge the batteries and power the loads. If loads are small, there's some solar that's unclaimed.
Plugging the chargeverter into your system could eek out the remaining solar. Any put it into the battery.
I know what you mean. That's kinda where my original thought came from.These are the thoughts that keep me awake at night. lol
The efficiency numbers for the Chargverter and the battery inverters in the 6500s are here on the forum In certain posts where people measure it.That’s kinda what I’m trying to figure out. It’s all conceptual.
Yeah...they're not... They could be off by 20W+You can also take a chance that the numbers in the manuals are correct.
Yeah, I found that one out the hard way myself. So have most of my relatives as soon as they take them to another room. Then they ask me why their 1 year old laptop keeps dying... ?Just going to add that my own experience with keeping Li batteries on a constant charge system.
It was not good, for instance the more I cycle my laptops down to 20% and then back up is the longer the batteries last. The worst case is keeping them pluggeg into the charger 24/7.
Go for it!I do appreciate all the back and forth. Nice to have a sounding board.
You can make it very complicated or simple.In a scenario where a generator is powering the chargeverter: does the Dry Contact power on/off the generator or does the Chargeverter.
I have my ac input breaker off all the time. Only time I turn it on is if I need to work on batteries or charge controllers connected to the DC bus.not sure if you could get it automated so it turns on/off at set SOC
but you could use a wifi switch or similar and turn it on/off manually when needed
I have dual lv6548 setup and 1 thing that bugs me with the ac input in SBU is that it uses 40w each inverter all night from the grid, thats over 1kwh each night
I could flip the breaker off manually but thats a pain for a small savings
wish there was a mode SB that was a selectable option with no utility, just solar or batts even though ac input is hooked up
To elaborate, dry contact from an inverter.You can make it very complicated or simple.
ChargeVerter doesn't have a dry contact.
To elaborate, will the dry contact from the inverter turn on a generator which is connected to the chargeverter which charges the batteries directly.In a scenario where a generator is powering the chargeverter: does the Dry Contact power on/off the generator or does the Chargeverter.
Your generator needs to support remote start via a dry contact.To elaborate, dry contact from an inverter.
Correct, a generator will have a two wire auto start.Your generator needs to support remote start via a dry contact. Will the dry contact know (via programming)
Assuming you use closed loop battery communication and SOC, It should.Correct, a generator will have a two wire auto start.
Will the inverter be able to turn off the generator after a preset SOC is reached or will it be confused by the Chargeverter providing power to the battery bank. This is my ultimate concern. Will the inverter know the state of battery vs the incoming amps thought the Chargeverter.
Would the increase battery voltage trip the generator dry contact when using open comms?It will work with either closed or open loop communications.
This is my concernWould the increase battery voltage trip the generator dry contact when using open comms?
