Old_Skewler
This is for an off-grid 15 KWh 48V battery bank (3x EG4s) connected to a Schneider 4048 Inverter in split-phase. The system has been running well for over a year. I would like to get feedback on how you'd deal with these warnings if you were running this system. I have a total of (3) alarm and warnings:
Here is the battery BMS information as read by the inverter. The most recent event happened when battery around 50% and 48V. Very small load on system, less than 200W.
And here is the battery setting screen with a 47V LBCO:
1. DC Under Voltage: i suspect the LBCO setting is too high and needs to be lowered? I don't remember where I got this 47V setting from (@SignatureSolarTech or Schneider).
2. AC Output Under Voltage: is there a way in InsightHome to access historical data and verify the AC load at the moment this event happened? Anything else I should be looking into regarding this event?
3. DC Over Voltage: this must've been the Inverter when in charging mode. I currently have the following charger settings.
Bulk/Boost Voltage Set Point: 57.6V
Bulk Termination Voltage: 56.8V
Absorption Voltage Set Point: 56.8V
I am not sure whether i should be looking into updating the charging numbers above OR increasing the HBCO. Any thoughts?
Thanks in advance for any feedback!
