yes, no, sort of .... there are 24 cells, in 6P4S. I gave them 10 days parallel with 10A charger and increasing voltages but then worked out it was going to take another month so built it into a battery, charged it with my 30A charger and then while watching the BMS top balance I "helped" it with a ~150w load until it was close and left it top balancing. since then I would imagine 800-1000 kwhrs of charge/discharge full time living in a van 0.2C max discharge and 0.1C max charge for 8 months - so not hard use at all.
Yeah, left it balancing - but even if it was low those numbers would be getting closer, and they just arent -
I don't think they are that out of balance that much, I watch it charge and they rise to 3.39 together (with charge voltage) then once the current drops cells 2/3 drop a little and 1/4 rise. Even taking to 3.65v/cell cell 2&3 don't get to 3.4 after that dont even get as close as to when there is a full charge current on.
I've also checked the bottom balance / low volt disconnect a few times in December due to not having power - and the cells are balanced 2.92-3.05 at my inverter cut off drawing full enough capacity too.
I've ordered a balancer anyway - to assist if i get this working, or to to the balancing otherwise. If i can be bothered to dismantle I may do a manual top balance again next week.
