You're asking for help on a Heltec BMS some 1180 posts down in a Daly BMS thread.Anybody???
No, this is not a Daly BMS thread. This is a Smart BMS/ OverKill Solar BMS thread.You're asking for help on a Heltec BMS some 1180 posts down in a Daly BMS thread.
I'd start a new thread with Heltec and some other key words to get the attention of folks who can help (sorry, its not me).
Oops, sorry. I hope i didn't derail this thread too much. All bolds and not all caps too?No, this is not a Daly BMS thread. This is a Smart BMS/ OverKill Solar BMS thread.
I'm adding a Heltec 3S 4S 5Amp Active Equalizer Balancer
Do I turn off both Balance Enable and/0r Charge Balance?
3.3.3 Balancer Enabled
The BMS will only perform its balancing routine if this option is enabled.There are very few reasons why this would ever be turned off. We recommend to keep it enabled.
3.3.4 Balance only when Charging
When enabled, the balancing routine will only be performed when charging.When disabled, the BMS will enter Static Balance mode, where it will balance when both charging and discharging.NOTE: Charging while balancing is usually more effective, because the cell delta is greatest at the top of the charge. We recommend to keep this setting enabled.
Based on the above definitions I would think you would disable both if you use an active balancer. I'm not sure if its necessary, but it seems like it would limit complexity and the potential for screwy behavior.Do I turn off both Balance Enable and/0r Charge Balance?
Can you explain what you are thinking/what you mean by this? I am not sure if I am understanding you correctly, but it sounds like you are assuming the BMSes will balance between battery packs, not just between individual cells in a pack.Will turning these settings off affect the balancing between the batteries or just cells on that battery/BMS?
Unless I am misunderstanding something, if you disable balancing on packs that have no active balancer, those packs will not have any cell balancing.Do I change the "Balance Settings" on all of the batteries in the bank or just the one with the Active Balancer?
The BMS's don't balance batteries between the packs. The only balancing done to batteries packs, is them being cut off at the top and bottom of each one. If one pack reaches the upper or lower limit before the others, it gets turned off from the rest for charging or discharging.Will turning these settings off affect the balancing between the batteries or just cells on that battery/BMS?
I have seen one battery send current to another battery when the charger was off. Both batteries had exact same voltage the next morning.
This is not due to any action on the part of the BMS.Will turning these settings off affect the balancing between the batteries or just cells on that battery/BMS?
I haven't been charging and discharging at the same time, but I believe it will show -5A in your case. IE, 20A in -25A out = -5A out.Hi guys, I have ordered one of this BMS and trying to know if with the APP I will be able to see the Amps coming in and coming out. I know i can se the current Amps (but I guess is Amps getting in minus amps getting out, if i'm getting 20 amps from solar and i'm using 25 amps on appliances, I wonder the BMS will say -5A)
My solar charge controller is the renogy DCC50S (don't have a screen), and at this point I'm thinking how i have to proceed to know in one single screen the amps coming in and out (same with watts), is the BMS able to show in the app IN an OUT? Maybe isn't able to show in the app, but using the @OverkillSolar arduino library I can achieve it.
The other option is to install a shunt, but in this case I don't know if the shunt is able to say the IN an OUT in different parameters (not one minus the other)
Thanks folks!
That's what I imagined, but I would like to know how many W or A are getting in and out. Maybe the shunt is going to be the only option, I would like to avoid the shunt, but maybe it is not possible. Thanks for the answer!I haven't been charging and discharging at the same time, but I believe it will show -5A in your case. IE, 20A in -25A out = -5A out.
Quick answer, turn the load off briefly. I think there is a Bluetooth module for your Renogy which has a app to monitor it. I think there is a thread on here about your DC-DC/MPPT. IIRC they talk about the BT module in it.That's what I imagined, but I would like to know how many W or A are getting in and out. Maybe the shunt is going to be the only option, I would like to avoid the shunt, but maybe it is not possible. Thanks for the answer!
