Are the 3x 10AWG wires sufficient for sustained 100A-120A current (e.g. for several hours) on the JBD BMS?
Especially since they're soldered and 120A seems to be close to the ampacity of 10AWG, I'm worried the solder could melt, under max draw, especially if one of the 10AWG was not terminated well. As it is, I am not too keen on terminating 3 wires in a single lug, nor stacking 3 lugs.
Would I be better served connecting the battery to the BMS with a single wire, and then my two BMSes together, with 3mmx15mm bus bars? Unless I'm missing something I feel like this might help maintain better balance between both batteries (i.e. less difference in resistance), eliminate the issue of crimping multiple wires into a lug or stacking lugs, and eliminate the chance that some wires carry more current then others, leading to overheating and failure.
Or, is this needlessly complex?
