OK .... I';m getting close to wiring my own system .... and one of the options I considered was the BMS recommended by
@Will Prowse .
I think the diagram below is the same / similar to the one on Will's website if you need more than 100A loads. Where my confustion comes in is that even if the BMS has low temp cutoff, the Charge controller is still going to try to charge the battery because it is connected direct to the battery .... not thru the BMS.
If you connect it thru the BMS, It seems to me that both the charge and the load will be disconnected by the low temp cutoff ..... and they have different requirements. It might be desirable to draw a little load to warm the battery up and then it would be warm enough to charge.
I have a Chargery BMS ordered because it will control seperate charge and load relays .... this is the only way I can see to have indepent control. This is going to make the wiring more complicated, but it seems to me that proper implementation of charge and load safeties is going to require seperate control.
Is there a separate port BMS available that has Bluetooth and low temp cutoff?
