Thanks Boboxx, that was it !@Denis Labelle se the language of your phone to english
I don't have an iPhone, but have read you want the Enterprise paid version....Read through the first five pages but have not got to page 23 yet, so I'll just ask.....has anyone downloaded the Apple App (called Xiaoxiang BMS) for this BMS and successfully used it with your iPhone? Thanks!
The free iOS app is restricted on what you can do. IIIRC the paid version is $5-6 USD...
Have the phone app. Works perfectlyI don't have an iPhone, but have read you want the Enterprise paid version....
Yes using it right now. No issues at allRead through the first five pages but have not got to page 23 yet, so I'll just ask.....has anyone downloaded the Apple App (called Xiaoxiang BMS) for this BMS and successfully used it with your iPhone? Thanks!
yes .... one time fee.Thanks all for the Apple iPhone replies. Glad to hear it works well. For the pro version is that a one-time fee or not?
I have one of these. The most negative pin on the JST is marked on the case - closest to the XT60.I have received the Battgo balancer and my Lifepo batteries are out for delivery on Fedex. Since I don't plan on any Xt 60 connectors can you tell me what the nomenclature for the secondary Battgo connection point is. I believe it is a 9 pin JST XH but I just need to be sure. Here is a shot of the connection point.
Another question from same newbie... I connected the new converter/charger I will be using in my travel trailer ( IOTA DLS-75 w/
IOTA IQ-LIFEPO Charge Controller ) up to my new battery bank to see how the charging cycle goes. When I initially constructed the pack all (8) batteries measured 3.29 volts each so I assumed they were likely a matched set and proceeded forward without any balancing. After charging for a couple hours I began to get “cell over voltage“ alerts due to the #4 cell continuously going into over voltage and the BMS shutting off charging. Once the voltage on cell #4 drops below 3.5 volts the charging starts again only to shut off within a second or two for the same reason. So on the bright Side of things the BMS appears to be protecting the battery as designed, however I’m curious as to this continued ‘cell over voltage’ and if it’s because I’ve got something possibly wired up incorrectly or something else I might have screwed up. As you can see in my picture the positive charge cable is connected to cell #4. Not sure if this is the cause of my problem of not. Any help or advice would be great. Thank you
Smart bms on AliExpress icgogogo is seller you can try.
I had that problem to begin with on the app with the yellow elephant. I found that in "Params Setting" mode , that if you hit the "next" on the app to tab to the next field down and then hit submit it works.I don't know what I'm doing wrong, having trouble saving any changes. I'm running the app Will linked to back at the beginning of this thread.
The one in the PlayStore in neutered..... I'm running it on my tablet running Android 7. Don't know if that matters.
I'm getting to parameters change page and hitting next, next, next, but not seeing the submit button. I think that's where I'm losing it...I had that problem to begin with on the app with the yellow elephant. I found that in "Params Setting" mode , that if you hit the "next" on the app to tab to the next field down and then hit submit it works.
Hope it's the same for you.
I am using it on my Samsung 9 phone with Android 10
FYI..... with 8 cells making a 12V battery, you can have a 2P4S or a 4S2P, but not a 4P4S..... For 4P you need 4 cells in parallel.....Ok I’m setting up Will’s 400 watt mobile system with alternator charging. https://www.mobile-solarpower.com/simplified-400-watt-fewer-wires-and-alternator-charging.html
I’m using 8 Fortune 100Ah LiFePo4 batteries in a 4P4S configuration. Here is Will’s Youtube video on this setup...
.....snip..........
