Bob The Builder
- Sep 25, 2021
- 109
Good question!Why are people wanting to use steel conduit, is PVC conduit not code?
ironridge racking is designed to use 3" tube (or 2") as the main structure that holds the rails that the panels attach to.Why are people wanting to use steel conduit, is PVC conduit not code?
There are lots of DIY solutions for pannel mounting. None of them will be sufficent if your system has to get sign off by a building inspector.I'm using super electrical struts for my racking. Wires fit neatly into the rails to keep them off the roof. Attaching to metal roof with special attachment, See picture! Super struts are 10 foot for $21.00 if you buy 10 or more, at lowes or Home Depot. Stainless bolts and washers extra.
The steel pipe is used for base structures. This is Ironridge ground mount, racking is still aluminum. https://www.ironridge.com/ground-based/Ahh instead of rails (extruded aluminum), people use steel pipe. I thought people were just using steel for conduit.
In typical market prices is steel the cheaper option?
Would used 2-7/8" sched 40 pipe work for you? Used as it is dicarded from oil fields.i have $2K of ironridge sitting on my trailer right now. Still trying to track down 3" tube for it.
perhaps, however that is in oil feild country and not the middle of the midwest were I am located at and shipping is typically prohibitively expensiveWould used 2-7/8" sched 40 pipe work for you? Used as it is dicarded from oil fields.
Miles of that stuff available at farm auctions and oilfield service co's. They usually ask $1/ft
I just ordered some 6" SCH80 the other day, for the two 21 footers, the price was down 30% from a month ago. Supply was 2 days out from 3 weeks a month ago.perhaps, however that is in oil feild country and not the middle of the midwest were I am located at and shipping is typically prohibitively expensive
