OffGridInTheCity
Solar Wizard
Thank you for these ideas - I'll order some of this flexible tubing and see if I can adapt it.Can you try and direct some of the cooling air flow from the generator towards the exhaust pipes?
Silica based muffler cement resists high heat and would seal threads but is brittle and rigid exhaust pipes tend to vibrate off and break.
Flexible metal exhaust pipe is the solution even if it requires a size adaptor. Suggest you try a marine place, they usually carry high quality flexible metal exhaust pipes as used for the marine and truck diesel heater exhaust , some are double wall for safety, this type of 1" stainless steel flex exhaust tubing is available on Amazon as seen at the link below:
Diesel Heater Exhaust Tubing
I tried some searches / orders on 1" ID exhaust pipe but they were >1.0" in actuality and I couldn't squeeze properly to 1". Tried some adapters as @Supervstech suggested and same problem - ID was not as advertised. But I'll try you're suggestion - at least it looks cheap!
