RE: Giandel advised - Ground/Neutral Bonding not supported - floating only - 24V / 3000W PSU
Hi All,
Giandel recently advised me they do NOT support bonding of Ground to Neutral with their 24V/3000W/PSU inverter.
The Tesla charger wouldn't function along with other devices that did soft 5mA pulse to search for neutral/ground connection.
Giandel's advice was to drop a GFCI (essentially becomes ungrounded GFCI like in old houses) - and then the device thereafter. It did trick some of the devices.
That said - I'm likely to abandon and purchase a 48V UL-rated Inverter/MPPT combo that can handle a Neutral/Ground bond near inverter or at whatever panel is used.
Would someone be able to help clarify if the Neutral/Bond limitation is related to High-Frequency vs. Low-Frequency Inverter architecture? Is the LF required? I've seen references to some HF units that can hand neutral bond as well, so I'm trying to understand what Architecture/Specification of the inverter conveys that it can handle neutral/ground bonding.
Appreciate the group's knowledge in this regard.
Hi All,
