I'm curious how prioritization works on these.
For solar-battery-grid, if solar isn't enough, will it dip into battery for only what it needs, or switch to battery entirely?
For solar-grid, without a battery, the same thing. Say the load is 1000w, and solar is only producing 500w, will it switch to grid for 1000w, or pull 500w from solar, and 500w from grid?
Can you set the battery depleted level and frequency? Say the battery runs down to 20%, will grid charge it up to 100% then have it just start depleting again? Such as at night?
Can you prioritize solar-grid-battery? Only using battery for things similiar to a UPS?
