Plum Crazy Rob
I know there is a thread running about mini split watts consumed. Appears we need a NEW thread how many watts in STANDBY??
Well now that’s definitely not a +.Uh oh. I realized apparently NOBODY checked this , and after 6 months of using one I didn't know the answer either!! Someone please check theirs!! 120W??!! Good news is its of course 0 in Solar only DC mode. And to be clear yes it's OFF -off not fan running or some ish...
Why would the fan run all the time when in AC mode?I'm not sure how the "idle" part is being considered here.
When its off its 0 watts.
When its on heat and not heating its 10 watts
When its on ac which runs the fan all the time but not running the compressors its 40 watts.
That's on my 28,000 btu units.
This has been the case for all that I know about.Why would the fan run all the time when in AC mode?
I have never seen that with any properly operating ac unit.
The mini splits I have keep the fan going all the time in ac mode and I actually very much like it that way. Think about what its like the second a normal central ac type cuts off or even a window unit. When the air stops moving it "feels" hotter. Technically its psychological but it happens and with the mini split keeping the air moving you get a bit of free "ac" from the coil still being cold and the air in the room is "moving". I like it.Why would the fan run all the time when in AC mode?
The one I got the readings I posted off of is on its own circuit run just for it .Yes and I think it's meant to contribute to drying the indoor condensate pan so it doesn't turn into a science project.
Again, I checked with unit set to come on in scheduled mode, after its shutoff time at night. No fan, display etc - when I thought it was "OFF" but connected to AC (and DC technically) power. I checked it in the evening and then again in the AM before it starts up to verify something wasnt in cooldown or such. I ran the new 240v circuit for this so know it's ONLY connected to mini split, no past owner mid run splices or any funny business. Maybe when @MrM1 climbs off the roof he can check one of his
how many watts do they use in standby mode?
It’s alarming to see this with the EG4 mini split. ?
This is true of conventional ducted AC systems and blower fans, they cycle .Why would the fan run all the time when in AC mode?
Yes. Since I currently have a single unit which is effectively undersized for the space it conditions, it justs runs all the time!! No problemoSo set at 75, it seems to cool down to 73, but then it doesn't come back on until 76-77. @Plum Crazy Rob do you see this?
BTW ... I just added a 4th Thing I learned above. About Turbo mode and the AC limiter. See post #413Yes. Since I currently have a single unit which is effectively undersized for the space it conditions, it justs runs all the time!! No problemo
So I turned the Grid back off after finding the revolting level of parasitic draw...I guess its DC only as much as possible, or those who have plans that it just stays on 24/7 are on the right track.
Are you saying, When the EG4 is totally off, but connect to the Grid AC power, there is a draw from the grid to the off EG4 of 100 watts. Is that the scenario that is being described?So ..I guess its DC only as much as possible, or those who have plans that it just stays on 24/7 are on the right track.
