Help with realistic view
Solardaveo
Scotland
I’ve been looking at pannels for years , we’re moving to land to continue farming but off grid Scotland uk ,
Our current consumption will drop due to cooking by log as apposed to electric ,our heating also log as apposed to gas and electric and other things we would leave too, but I am trying to base it off what I got now so there will be backup.
I’ve had quotes and talks with people with soma y mixed views from some telling me 5kw is plenty to others saying even with 24kw I’d need generators etc and solar will never do it
I quickly came to see that plenty of people was maximising sales or garenteeing a sale
So I’m here to find out honestly what I need , the solar will be fitted on to a sheep barn built with solar in mind,
Current consumption is 18kw a day that’s all tools welders fans lights ovens the lot,
My main run is the workshop lights and drying room which run every day from 9-9
Which pulls 10kwh a day
My other usage is house lights to to and Xbox and fridge ,
I’ve accepted il prob be better running the fridge and freezer off lpg
Lights I could do from their own solar charge lights seen a few that are quite good .
I was set to buy 24kw solar and 48kw battery’s 48v and then I’ve been told that’s way too much and the batteries should take my winter months with a 12kw pulling 5kw in winter and pulling 20 in summer that a year picture was better to look at and that I am around 6500kwh a year then a 12kw will put 7kw total ?
To be honest I’m lost
Play around with this. Is an interactive calculation tool that will give you how much you can expect to produce depending on a number of factors like, where you live, what orientation the panels have, how much of them you want to put, size of battery, etc...
Me too after reading that post 😅 ... Can you tell us , exactly how much power you use per day total , winter & summer pls if you can
From that it's easy to help size a solar array
The rule of thumb in the UK is 1x solar production in winter , 5x in summer
Eg. a 4,000w solar array , would produce 4,000wh average in winter, 20,000wh in summer
it's a big swing mostly caused by the short days in winter , I think you'll get even less up there in Highlands
thanks bit confusing that lol im sure its simple when you understand it , i thought it was going to be like sims world or roller-coaster tycoon , got excited then, the pc array says 1kwh panel installed there but seems like i should enter the wattage there but below looks like the number of panels set at 1000watt ?, hm not sure what i am looking at lol i wish i was been playing with all sorts of calcs, saw a guy YouTube using a drawing like planner 3d enter panels geo etc boom tells ya stuff but i cant find that program
my main hard usage when we cut out most stuff we dont need shows up as this for winter
Energy consumed per day:
kWh 15.5
this is my work , and my house powered 5657kwh a year
my fridge and freezer are using an extra 12kwh a day ( this is where i guess a generator would be best to run the fridge and freezers and my gasifier etc ) 4380 kwh a year
as thats 10037 a year if all together , unless there is a better way to run this i feel i need a big ass 24kw system system lol
but the quote i get back recently thats made me over think this is he sent a link saying this below, and thats said even with fridges on the solar i could run this on a 12kw system ? providing i got the batteries
How much does a 12kW solar system produce per day?
On average, a 12kw solar panel system can produce between 30 – 66 kWh per day, 900 – 2,000 kw/h per month, or 10,800 – 24,000 kw/h.
How much does a 12kW solar panel system produce?
Time period Energy produced (kWh)
Per day 30 – 66 kWh
Per month 900 – 2,000 kWh
Per year 10,800 – 24,000 kWh
I bet a LOT of European winters get far less than 1x per day.
It will be such a big system, consider not messing with LPG refrigerators and such. Members here on diysolarforum report having had issues with those appliances plus they can cost quite a bit more.
Your drying room runs in the winter? Perhaps you will describe what they are for?
It really depends where you are,
the south of France, Spain, Italy, Greece often get brilliant weather even in the depth of winter
Now northern Europe like the UK , Germany , Netherlands, Scandinavia, that's a different story 😄
I know this website can get a bit confusing, but the thing is to insist on it until you understand it.
First you click on the map on the left to pinpoint your location, then you select the type of system you want to install on the right. In your case for what i have understood you want an 'off-grid' system. And then you just fill the data you would like to test to see how much it produces.
If you dont mind sharing your coordinates i can plug the data for you and give you back the info.
we had a grey overcast summer, cloudy autumn . I am hoping for a sunny winter 😁
it is an el nino year, which is always cloudy , rainy and grey summers and falls....
do prep youself for a rather cold Jan-feb-Mar though....
i surely hope this will be cold, but sunny and not like last year a cloudy muck
is it worth looking at off peak tariffs and buying (and storing) power in a large battery bank? In the UK you could use https://www.fogstar.co.uk/collections/solar-battery-storage to buy your batteries from a good supplier (i have used them myself BUT no connections to them) at a very good price, especially if you assemble them yourself in your workshop. You could get 30kw of batteries for £8k which would effectively make all your electricity use at an off peak rate if you can get one? Then any solar you add over time will reduce your need to buy from the grid. you would of course need an inverter big enough to charge the batteries during the time period of off peak. Sunsynk do some well priced hybrid inverters that are UK approved. A large inverter is probably going to cost somewhere in the region of £2-3k.
Do you have the potential to ground mount the panels so you can get the perfect orientation, possibly using the structure as a shelter?
our land is in north west scotland, uk.
MisterB1959 yes i have open field , i planned to put them ontop of a barn i build for them, , ive even though about putting it on a roundabout to move during the day lol, so yes i am flexible,​
@KITROBASKIN yeah its a workshop, we do alot of woodwork, painting varnishing etc , so run extractors and fans, equipment that keep the room stable, and our tool useage during that time we also use the rear of the room for chicken rearing, which on the plug we use says is responcible for about 12kwh a day of useage , so on days we use less that would be a bonus but this is my max main need​
our actual useage is small apart from fridges which i am figuring out if there is a better way to do somehow ,
so daily useage is 15kwh, might i add i am a family of 12 people, lol
If the barn has open sides, it might be worth getting bifacial panels, just to squeeze that little bit extra out? I think the ideal height for bifacial panels is around 4m, but you would need to confirm.
You were probably not far off there. You would still run short some winter weeks and want some kind of generator. No way to avoid a generator completely unless you're willing to be without power.
Did you have specific equipment in mind?
Something i didn’t understand at first.
You panels can power your inverter and charge the battery at the same time if they have enough to meet demand.
It is when usage is higher than panel supply that creates the biggest need for batteries. Like at night when there is no sun.
Also you can’t charge batteries while using them. So battery bank size and charging rates have a lot to do with use as well as supply.
New here myself but it was a hard initial learning curve to understand some points for me so hope that helps you figure it out better.
Get a way to measure individual consumption for devices you will be using instead of the whole house and you will get a better picture of your needs instead of wants. You’ll be able to see what the wants are too and know which ones you can accommodate within your “max” limit you set for your system.
They make little plug in meters for it.
Winter production looks pretty grim in the Scottish highlands, 5kWh per day in December out of a 24kWp array.
You can be sure that 24kWp/12kWh is not undersized at all.
Maybe as much as 10kWh? I'm not as familiar with that tool. Also needs to be calculated for a precise location.
For example, a 24kwp system with panels inclined 60 degrees oriented to south, in Dingwall in the Scottish Highlands will produce 500kwh in December, the lowest productive month. About 16 kwh a day. 2680 kwh in May, the highest productive month, about 90 kwh a day.
If you give me the name of a town near you i can give you a more accurate data for your location.
