Sorry been away working a more accurate location to where we are meant to be is
- Nearest post code: G83 8SA
- GPS coordinates: 56.0317, -4.50533
I don’t have any equipment I mind though I don’t mind a hunt, eg a dude on eBay selling 74kwh 48v deep cycle batteries for £4000 in good order seems good , not keen on li with the damage it causes fires it can cause etc but if I need I will get I know you need double when using deep cycles too ,
Solar panels I found a guy selling them if bought more than 20 pannels the price drops to £109 a 5xx watt or 4xx watt for £100 pv , sounded ok there is a lot on eBay etc too but I’ve seen some can be crap china pannels etc too so learning to see difference would be needed lol
Otherwise I am open to advice
Generator wise I do composting and plan to expand my composter to a biodigester and harvest the gas which using my compressor I can bottle up , so can run lpg generators from that. Also do small scale petrol recycle from plastics etc so can do this as extras just cause I can do why not, also gasifiers seem to be growing in popularity to run generators etc small scale farm in Scotland runs a small unit which pulls home 49kwh a day just below the theeshhold so I plan to play with these too as a fabricator but before I apply these I’d like to make sure I am 100% from a solid source like solar , diesel gen on red d lpg generator
Also if I have running water and I can make enough drop from I will harness that too which can drop the need for solar at all but until march we wont know what woodland we lock down or what it has , so for that solar will be in my lorry to guarantee my power .
I plant to fill my lorry with everything we need and go set up solar /water /toilets etc and get on generator will carry my workload till solar is active so need to work out a system I can start buying that will work
