Does anyone know if the Heltec 5 amp or 1.2 amp 8s active balancers would work in harmony with Overkillsolar's 8S BMS? Seems to me the active balancers would be a good add on for the larger LifePo4 cells, especially the 280ah ones.
I don't think those values are accurate. I asked if I could have it set to 2.5v and Echo said just note it when placing the order.You are ok with a low cell disconnect of 2.1 volts?
Its good that they will set it for you but what is the default?I don't think those values are accurate. I asked if I could have it set to 2.5v and Echo said just note it when placing the order.
One of the links I posted shows low cell disconnect as 2.8v. I doesn't make sense that the numbers are all over like that.
Also, I checked Chargery and Daly and both of their documents showed low cell disconnect as 2 or 2.1. I know both of those are user changeable though.
Also curious what the difference, and pros/cons of 'inductive' vs 'capacitive' active balancers would be.
Resistance balancers are basically constant rate.Good point. Would really like to learn more about this. Heltec's price is great for any of the active balancers.
What app is that?I don't remember the defaults on mine, but these parameters are all configurable through the app as well.
I'm pretty sure the Chargery default value for over discharge protection (P) voltage is 2.5.
I feel like this Heltec BMS is another good option, that might turn out to be pretty popular.
I knew I saw Heltec somewhere. I just looked at yours. This link shows the app - https://www.aliexpress.com/item/4000776885236.htmlI don't remember the defaults on mine, but these parameters are all configurable through the app as well.
Active balancers slow down as the voltages converge.
Would be curious to hear @upnorthandpersonal impression so far.
In my opinion it's great. It has tons of configuration options (like charge an discharge over current protection, low temp cut-off that is configurable and works, over and under voltages etc.), robust enclosure without any dongles dangling about (on the later models they make, the ones encased in black aluminium). They can also actually handle the advertised current and have a pretty high charge current compared to others. Once I had them configured, they just sit there doing their job and I haven't had to think about them since. I introduce test failures at times to see if they (and the rest of the system) operate as they should, and no issues thus far.
Thanks. For some reason, the Wordpress Heltec page doesn't show any of the BMSs that are on the Aliexpress page.FYI: updated my BMS poll with an entry for Heltec BMS (including links to what I believe to be the official Aliexpress, Alibaba, and website links. and pictures of the BMS and App.
Is this one user configurable?In my opinion it's great. It has tons of configuration options (like charge an discharge over current protection, low temp cut-off that is configurable and works, over and under voltages etc.), robust enclosure without any dongles dangling about (on the later models they make, the ones encased in black aluminium). They can also actually handle the advertised current and have a pretty high charge current compared to others. Once I had them configured, they just sit there doing their job and I haven't had to think about them since. I introduce test failures at times to see if they (and the rest of the system) operate as they should, and no issues thus far.
