shavermcspud
- Mar 12, 2020
- 576
Hi all
I have a Solax boost 3.6kW inverter, dual mppt trackers with oversized 14x350watt sunpower (4.97kw) PV all in one orientation currently in a single string to one mppt input.
This is a matched kit supplied by a well known UK company btw.
Is it best to use both mppt inputs and split the string down to two?
The reason I ask is i seem to be maxing out at exactly half the rated output of the inverter even during excellent conditions, the supplier said to use a single input which I have done with one single cable run, the manual doesn't state either way and if there is a limit on each mppt input or whether a single mppt input can support the full 3.6kW output.
Anyone have any info before i run more cable out
Cheers.
Cheers.
