I decided to bottom balance since my operating range at the top end is limited by my midnite classics. I can set eq voltage, absorb voltage and float voltage. I set them at 56.8 (EQ is also disabled), 56.8, and 40. When the solar charging pushes the bank voltage to 56.8 I am done but my SOC (based on a coulomb counter indicates about 80%. I will be discharging down to 10% or so. Yesterday I let my bank discharge while monitoring all cells. I stopped the discharge when the lowest cell was at 2.7v (these are new cells and I had not balanced them yet). The difference between the highest and lowest cell was .25 volts when at the low SOC. (At 50% SOC it was only .01). I took the whole bank apart and connected all 64 100 ah cells in parallel for 18 hours. After that I checked all the cell voltages and they all read exactly 3.010. I reinstalled them and monitored all cell voltages as I reconnected the load. They were within .01v under load and as charging with the genset was started. Maybe not perfect but plenty good enough as far as I can tell.
I will say that being able to log individual cell voltages during discharge and charge and see them on a graph is really helpful in understanding cell charge curves and the degree of cell balance you have. The breaks in the graph happened when the load changed (Heat gun switched off, on) or monitoring was paused for a bit.
discharge curve, before balancing :
A short discharge curve was made from cell data collected right after the pack was reinstalled in my system, before charging, under load:
