I just meant only sell at max rate, and take the rate plan with biggest spread between max and min.
Gotcha - I would have called that ‘time-shift + common sense’ reserving ‘arbitrage’ for those trying to ‘make money off of the grid’ by exporting battery power during peak hours, but whatever.
It's definitely far from 100% certain that planning was done. Just anecdotally there's a few people asking about expansion here per year, and a few on Reddit, because they didn't plan ahead or it was too far in the future at the time of original installation to make sense. Also depends on the sophistication of the customer and the discussion with the installer. Also there could have been a massive design flaw. 1kW may or may not be enough, depends on how good the remaining area for installing solar panels is. In ideal conditions (5 hours per day) it would get close. But the ideal positions may have already been taken up by existing panels.
Yeah, so what gets interesting for those folks is, if they add an approved hybrid for time-shift and self-consumption and then they add a bit of new DC-coupled solar to the available MPPTs to charge their battery with extra energy to offset overnight load (but not to export), do they need to get permission from their utility for those added panels?
I'm pretty sure no amount of expansion would be able to cover both EV and HP on my property. IIRC my math says 9 year break even with 18kpv @$10K (DIY install), so substituting the 18kpv with a $4000 cheaper inverter would be a significant difference. For a turnkey install it will require a lot more cost drops or unfavorable POCO rate changes to make sense.
Of course, if you are maxed out and still cannot generate more than your consume annually, you want all your consumption when rates are low and all of your export to happen when rates are high.
But you’ll still be better-off if on any given day you either exported or imported, but never both…
The math is very different from net producer (which I personally have not analyzed in depth b/c it's not important for me, but I did enough to decide that it's pointless as a net produce)
Sounds like we are in perfect agreement then.
The primary thing making this easier/harder is that the 9540 hardware is not available so you cannot export to the extent needed by the above planning without being detected.
Detected how?
If you go through a full day with zero export until your battery is full and then export to sundown when you switch to being zero import until the next morning when the cycle starts anew, can that be ‘detected’?
If you go through a full day with zero export without any export and the continue into the night with zero import until your battery is drained and you start importing to offset load until sunrise, can that be ‘detected’?
The secondary thing making this easier/harder is that the necessary 1741 Power Control System variant (Export Only
(outback description of what these are)) and export sell configuration may not be supported by the inverter (which is only a programming thing, but it is still a dealbreaker). The 18kpv definitely has this capability. And note this is a capability of PowerWall, so it's deemed useful enough to be in the most mainstream of inverters.
From PowerWall
docs (and talking to neighbors)
Could not follow the link - can you provide Cliff Notes version of the concept / capability?
If it refers to exporting to grid from energy stored in battery, I’m coming to the conclusion th as t thee as t is not terribly important for modest -sized / modest-cost systems.
