I’m back for more punishment. Can’t stop reading threads and causing myself more feelings of ignorance.
I hope you're enjoying the discussion, this is one of those threads where we kick around ideas, opinions and of course sometimes a little banter.
To stay on topic of the thread: what would cause one to consider the luxpower or solark 12k/15k options a higher “tier” than say the Growatt or Sungold/sigineer 12k? In following both the solark and lux/eg4 threads it appears that we are coming up on 1yr old devices that they are still facing numerous growing pains on
I would not consider them higher tier. I would consider those 2 inverters filling a specific need in the market but are not proven to be solid performers, at least for the Luxpower. Sol Ark had a head start so it is slightly less troublesome at this point.
The EG4 6500EX was a no go for me after 2 attempts with different pairs of inverters. I'm not the only one and I was not impressed with the sine, very dirty and I could see this causing problems. One member here told me privately his TV was fried the same day he installed a replacement pair of the 6500EX's.
In the process I installed the LV6548's and ran those thru the tests. Clean power, sine is great, no lighting problems. So when I returned the second pair of 6500EX's, the LV6548's went back in. Solid performer, I have no issues. My only problem was the low VOC rating and my array 420 feet away. Installing the EG4 SCC's will work out perfectly, I was slightly overpaneled on the 6500EX's, now I can capture another 300 to 400W in good sun. I'm actually seeing the EG4 SCC that is currently connected commonly output 4.3Kw with 4.2Kw of panels.
I wouldn't consider the Luxpower at this point, wait until the bugs get worked out. Sol Ark might be OK at this point, you just don't see that many posts with problems or even posts indicating many members purchased the Sol Ark.
It would appear idle is higher on the Growatt. But it has a more significant surge capacity.
I asked James what the actual output of the 18Kpv unit is solely off battery which would be night time usage. He ignored it, so I question the "marketing" of the product. If you look at the spec sheet, the surge power is listed as 5 minutes and 10 minutes, no continuous rating solely off battery. It is a red flag to me if the owner of the company can't/won't answer the question.
Sol Ark does give that spec, kudos to them.
The luxpower and sol ark both accept a much larger PV and at much higher voltage.
But the Growatt can still receive up to 7k of PV with a 250v capacity which seems “reasonable”
That notion though as well, one could add another SCC directly to battery for additional PV
I won't be using any of the MPPT's on the LV6548's once the other SCC is installed. I have the option to always install some extra panels I guess. Maybe use one for SE facing array and another for SW facing array.
At 3x the cost, in a purely offgrid home, what benefit does the HF options offer vs the Growatt and it’s siblings
From what I have read here, those running off grid with the LV6548's were quite happy with the performance. It is a solid performer that I've seen, can't say that about other units from my personal experience.
