I'll just leave this here so you can all stop me from ordering 2 or 3...
- 2 MPPT input channels, 145VOC Max
Get thee behind me!I'll just leave this here so you can all stop me from ordering 2 or 3...
50 amps input per mpptImpressive.
Years ago yes it was.Impressive.
60amp charger seems weak since the tp6048 is 120 amps.I'll just leave this here so you can all stop me from ordering 2 or 3...
I would seriously consider a couple of those if it weren't for the low voltage limit on PV.I'll just leave this here so you can all stop me from ordering 2 or 3...
Idle consumption was part of it, 2 of them would be less than one lvx/tp 6048 (according to specs).60amp charger seems weak since the tp6048 is 120 amps.
But if you buy two of them I guess thats 120amps.
But thats $1800 even on sale.
Then the pv isnt but 300 volts max using both connectors to the sungolds 450 volt max.
Is this all about idle consumption or something?
Ahh now the 3 phase part would make sense.Idle consumption was part of it, 2 of them would be less than one lvx/tp 6048 (according to specs).
I was more interested in the 3 phase output with a single unit...
The 145voc max is the biggest downfall, really a deal breaker for me since I've been spoiled with using high voltage strings already.
ThisThe 145voc max is the biggest downfall, really a deal breaker for me since I've been spoiled with using high voltage strings already.
Definitely a candidate for adding a separate SCC of higher voltage.Impressive.
Increasing amps increases power loss.Get thee behind me!
How?Increasing amps increases power loss.
How?
From Ian's website: https://watts247.com/product/hybrid-lv6048-split-phase-120v-240v/I was more interested in the 3 phase output with a single unit...
One again I was reading specs while I was tired and got it wrong. I saw 208v in 1c and got 3 phase back to the edit button in my other post.From Ian's website: https://watts247.com/product/hybrid-lv6048-split-phase-120v-240v/
"1d) With three inverters, a three phase ( L1 , L2 and L3 being 120 Degrees apart, as in three phase systems)"
I see nothing about 3 phase with one unit.
I've thought about this. I'm going to build a cart unit like Will did in his recent video. Already bought the cart and will be getting an inverter and battery, probably as soon as I can make a decision. I probably should start a thread and ask the brain trust for recommendations. The problem I see with this unit is mostly weight and dimensions. I think the biggest advantage of the EG4 3K is how small and light it is, at least for this cart build. Plus I don't know that 240v is a big need for the application. @Gavin Stone did a couple videos on it too, with a lot of positive feedback. But the LV6048 is 66lbs vs 46 and 24" x 24" vs 17.5" x 11.6" on the EG4. That's going to make a big difference on a cart build.A single MPP 6048 would make a great little mobile 'solar generator' since you get 120 and 240 output with just the single unit.
And once you have this on your property, you will quickly see how handy it is:I've thought about this. I'm going to build a cart unit like Will did in his recent video. Already bought the cart and will be getting an inverter and battery, probably as soon as I can make a decision. I probably should start a thread and ask the brain trust for recommendations. The problem I see with this unit is mostly weight and dimensions. I think the biggest advantage of the EG4 3K is how small and light it is, at least for this cart build. Plus I don't know that 240v is a big need for the application. @Gavin Stone did a couple videos on it too, with a lot of positive feedback. But the LV6048 is 66lbs vs 46 and 24" x 24" vs 17.5" x 11.6" on the EG4. That's going to make a big difference on a cart build.
