Zwy
Emperor Of Solar
I guess you can abuse the SCC with PV overvoltage, then post a video on the internet blaming the inverter is at fault?
We've been working with this individual for a while. Sometimes it's tough to get people to change their minds about how things work. He fried that board with PV, so F11 won't clear on its own.I guess you can abuse the SCC with PV overvoltage, then post a video on the internet blaming the inverter is at fault?
Probably something like the Trina which is 50VOC. 10 panels in series=500VOC10 x 400W bifacial panels in series. Did he mention the brand so we can check the Voc?
EG4:
Max PV Array Open Circuit
500VDC
PV Array
90VDC - 450VDC
At the 4 min mark he goes on about a switch so the inverter cuts off in over current, then over voltage. Confusing to say the least.Max Voc is a hard limit. If you don't know that, you should find a new hobby. Or hire a qualified electrician.
True. We have a saying that's widely used in the framing trade... f*ck it, nail it. Definitely not to be applied in solar. I triple check stuff and ask questions when i don't know something about solar.No matter what you do. It's important to understand how to do it.
Every problem looks like a nail when all you have is a hammer!!True. We have a saying that's widely used in the framing trade... f*ck it, nail it. Definitely not to be applied in solar. I triple check stuff and ask questions when i don't know something about solar.
I’ve watched a few of his videos. I think he fried the first inverter with over voltage. Then fried the second when he didn’t use a precharge resistor. That’s just a guess though of course.
They do. But I think he has some other batteries on the side there also. It’s been a while since I watched the video.Don’t the LiFePower batteries have precharge built-in or is that later models?
I vaguely remember the precharge circuit not working correctly on a lot of batteries. Don't quote me on that though.Don’t the LiFePower batteries have precharge built-in or is that later models?
Yes. Midnite has charge controllers that allow you to go over the max voc. It's called hypervoc and it adds the voltage of the battery in addition to the max rating to allow for some wiggle room. Example- midnite classic 150 is rated at 150v max voc but when running it with a 48 battery, you have a safe limit of 198 voc. Great feature when you are pushing the limits of your CC and cold weather puts you over the top.Is there ANY charge controller on the market that can protect against going over the the maximum allowed voltage for the controller? I don't know of any.
