Lighthouse Beacon
Following the Light
Tried both will try to unplug everything and let it sit for a minute, pretty annoying
Nothing working. It’s just a POS I guess.
also if you plugged in usb after starting the system, you would have to reboot.......same with the HDMI port.......once the reboot happens our touch screen HDMI monitor will work as wellTried both will try to unplug everything and let it sit for a minute, pretty annoying
Well that's not good. I had an issue today where the PV was dropping every so often but not regularly and it would cause the inverter to switch to grid. Ugh!.....and of course that couldn't the end of the story right? ....
Solar Assistant and the Raspberry Pi seem to be randomly disconnecting from the battery and I have to go to configuration and disconnect/reconnect....
...and so...after all that....I've switched back to 'inverter values' which at least doesn't disconnect every little bit...
Hmmm, odd, didn't have to do that with usb to pc on mine when I used italso if you plugged in usb after starting the system, you would have to reboot.......same with the HDMI port.......once the reboot happens our touch screen HDMI monitor will work as well
That's good, they must like you they ship quicker to you lolLooks like my Sungold Battery communication cable has shipped...or at least is 'fulfilled' ... yep... coming USPS...expected delivery Saturday...
Just saw this, I will try when I get home. If I ever get through the forever line at the pharmacy ?follow up on cables.... I just 'built' a DB9-> RJ11 from one of the non-working cables I bought while trying to get this to work and success! will post a better wiring/connection/drawing/photo in a bit...but the connections listed above are correct (disregard the colors depending on what you are working with!) just make sure the pin assignments match/connect.
well here ya go nasty wiring diagram:
You should be able to adjust/change that in your settings....all dependent on details and what you are wanting to do of course!Well that's not good. I had an issue today where the PV was dropping every so often but not regularly and it would cause the inverter to switch to grid. Ugh!
Me either....seems like @Sandiegoarea has got some weird shit going on.Hmmm, odd, didn't have to do that with usb to pc on mine when I used it
Oh no.... my initial order of Inverter and two batteries shipped within a week but one of the batteries got lost/delayed.... the second order of additional batteries was weeks and weeks! Gawd only knows how long the rack mount is going to take...hasn't been fulfilled yet and it's been over a week sitting there. OH and I love how they take your money right away and then ship later....That's good, they must like you they ship quicker to you lol
no just experimenting. Bought a touch screen to mount next to the inverters for HDMI output, but SA said you cannot connect a cord before turning on device and 56KW battery system so that i dont have to whip out my phone all the time, plus it helps if wifi goes down like it does with SA, then i just tap the screen and boom see dataMe either....seems like @Sandiegoarea has got some weird shit going on.
check voltage, i also have two growatt 12kw inverters, the difference is voltage, sungold wants the voltage above 200 normally to it works better and works perfectly at around 420volts. so when i had my 36 panels wired at lower for growatt, it wouldn' t hold during the day when it got cloudy. changed the string layout and runs like a champWell that's not good. I had an issue today where the PV was dropping every so often but not regularly and it would cause the inverter to switch to grid. Ugh!
Cycle usb power, option under USB devices in SA.I started a ticket with SA, this thing won’t connect to inverter via usb anymore. I tried multiple cables, shut down everything etc. how do I wipe the sa install out and re install fresh? Do I need to flash the ssd to get to the setup wizard?
Done everything but the ID number thing can you elaborate on thatCycle usb power, option under USB devices in SA.
Change USB port on pi and cycle usb power again if that doesn't fix it.
As a last resort change the ID number in the inverter.
I'm new to SA so maybe someone else can better answer... I do want to know what ..why ..I started a ticket with SA, this thing won’t connect to inverter via usb anymore. I tried multiple cables, shut down everything etc. how do I wipe the sa install out and re install fresh? Do I need to flash the ssd to get to the setup wizard?
Menu setting number 30 in the inverter. I went from 1 to 2.Done everything but the ID number thing can you elaborate on that
I think he, like me is just using a standard USB cable to USB type a (printer type cable)The logs seem to show the usb to serial part of your cable having problems. I had the same issue log wise when I had a bad connection on the ethernet plug with the pi. Reseated the cable and it worked fine after that. With it finding it and disconnecting its dropping the connection. Either a bad connection (which you said you checked so not likely that) or the converter is going bad.
Mine is a serial to usb connector that then connects the cable that goes to the inverter. I'm not sure if yours is all made into one or not.
