Here my update on the battery balancing. Since with 55.2V, I was still getting OVP status, on Tuesday I reduced the charging voltage to 54.8V.
Today is the first sunny day.. 1:30pm and already 10kW from the panels.
I won't report voltages read from the rack battery any more as they are meaningless if the battery is still connected. Took me only a month to figure that out
Instead the SOC per battery, and BMS status and charging amps:
#1 96% - idle, 0A
#2 88% - chg, 0.9A
#3 82% - chg, 1.5A
#4 94% - chg, 2A
#5 100%- chg, 3A
No communications. User mode. Why does #5 get 3A when full..?? The rest makes sense.
#1 has unbalanced cells, about 150mV between lowest and highest.
#2-#5 are much better balanced on cell level.. about 10mV between low and high.
