CaliSunHarvester
Yes. You'd use Bus Bars, batteries to bus, inverters to bus (recommend a class T fuse as well).
More mppts and panels are never bad.
So I would have 2 inverters on the bus? There won't be an address collision? Seems like the SGP wants to be address 1.
Would it be like having an external charger parallel to the AIO, also sharing the bus?
With 2 of the 10kW units, each can pull nearly 200A, so I would need a bus bar handling 400A, better 500A. Is that all? Sounds easy.
