42OhmsPA
What's in a title?
When there is hardly any power from solar utility with charge with more power, this only works when you are running in passthrough (UTI). Basically it will charge with whatever solar is available and whatever utility as long as no max amperage setpoints are exceeded.The "manual" is such junk. Might be worth it to learn Chinese and get the original.
What exactly constitutes "sufficient" for *charging* purposes?
I'm running in SBU with SNU charging and I see 0 utility usage unless I change to UTI.
Edit - wrong mode.
