here's my update on my attempts at Utility charging. My battery bank has reached quite low levels under 20% SOC, due to increased consumption with decreased sunshine.
It seems that one major issue for other operators was the switching between solar/ battery/ utility when the voltage drops below [04]. I think it's why so many disabled BMS communication and changed the battery to type "user".
When BMS communication is enabled, that number is 49.2V set by the batteries. I think that's too low. If the system is at 49.25V and a big load comes in like the 4.5kW water heater, I think that could be bad. I would rather have this number higher like at 51V.
I turned off BMS communication but did not go into battery type "user".
I had [01] set to UTI, and indeed, it was charging from utility as it should.
As soon as I change [32] from SLA back to 485, the box beeps around, relais are clicking, and it won't charge from utility.
On a side note, my problems with the total amps going into the battery not matching the setting [07].. I had not realized that [28] also limits it. The total amps going into the batteries is the smaller of [07] and [28].
Because of my lack of knowledge & confidence, I still believe it's better for my system to use full BMS communications. So, I probably from time to time will force charge the battery bank as I see it necessary, by switching [01] from "SbU" to "UTI" while comms are disabled.
I also measured the continuity at the generator dry contact pins which had been suggested a few days ago. The manual's section on this gives me a headache. While at 51.6V, I think I measured continuity between 5,6 but not 6,7. I won't go back for a while.
