Kenny_
Interesting.... my legs are definitely unbalanced...just because of what is connected. But this happened when I was away and with very light loads. Hmmm....I periodically see “Master-slave chip SPI communication failure” but it always clears itself. I had 1 time it didn’t and I rebooted system. I feel like it happens more when you’ve got a lot of demand on a single leg of your output and not a lot of draw on your other L2 leg. Make sure L1s not getting a bigger work out. I moved more over to my L2 to balance my surging and it only happens maybe once a month now if even that, never requires reboot usually blinks fault then instantly clears, maybe try shuffling some breakers if you’re concerned
I don't like to think of 'shuffling' breakers....guess that would have to be shuffling in my transfer switch...that certainly wouldn't be as bad as my main (old messy) breaker box.
I'm still hoping to get the entire breaker box replaced under the HEEHRA act if they ever get things in place here in Colorado.
Thanks for that input @Lighthouse Beacon ! How's your system working these days?
