Wescottpower
I have a sungold power 12kw running a supplemental breaker box with my primary circuits on it. I have 10 550w panels and the kWh meter on the inverter says I’m only making about 4.5-5.5kwh per day. Panels are at optimal angle for the time of year facing south with unhindered sun exposure from about 8am until 6:30pm. Our household uses about 2800-3000 kWh per month and I wanted to use this as a supplement but I’m not feeling I’m getting the output I should be. Not sure what I’m doing wrong or if that meter is accurate. I have 2s3p going into pv1 input and 2s2p going into pv2 input. It’s a 48v system with 16S 202ah battery bank. Daly 200 amp bms and active balancer. I added more circuits to my sub panel this weekend and the inverter runs on PV mode all day long and keeps up. Readout on inverter states anywhere from 16%-45% throughout the day. I thought adding more circuits would get me more kWh’s but still the same daily meter reading. Any ideas?
