OffGridInTheCity
Solar Wizard
I agree, Batrium 'burns off' the higher cells to lower them. As to why the info is not making sense - as I wrote above, I've never unerstood the Batrium Telemetry report mah metrics and just took to monitoring the Blue Bars + I extract the cell voltages and put them in a DB so I can report on Highest / Lowest and max difference for monitoringWhat I don't understand is why do the lower voltage cells have higher bypass mAh? Wouldn't the higher value cells be the ones burning off mAh? Or do I have it backwards?
For example, it's been about 5 months since I balanced and I'm running 40mv to 80mv differences thru the charge cycle. These are a variety of Lithium-ion cells so it's not as tight as you're LifePo4 but I don't need it tight - just to be consistent.
Here's an example of my dashboard monitor line... currently at 50mv max difference:
Lowest 7: 3.64@P88, 3.64@P100, 3.64@P101, 3.64@P102, 3.64@P108, 3.64@P109, 3.65@P16 (0.05v) Highest 7: 3.69@P12, 3.69@P14, 3.69@P27, 3.69@P55, 3.68@P7, 3.68@P6, 3.68@P5
Lowest is Pack 88, 100, 101, 102, 108, and 109 at 3.64v. Highest are Pack 12, 14, 27, and 55 at 3.69v.
