sunshine_eggo
Happy Breffast!
I'm a long time Batrium user.
Reading thru the thread, I don't recall reading that the cells were ever in balance so I ask.... Were the cells in balance when you 1st built the battery or did this imbalance occur after some time period?
I use Auto Level on Lithium-ion 260ah packs and it can take 4-6 days to 'tighten the balance' by 20mv and you've got 90mv max difference in the 1st post. Patience is good in these situations - especially if things are not getting worse
FYI - the overall battery voltage does not mean the individual cells (in series) will have a specific voltage in relation to each other. They can vary widely and is one of the reasons BMS's are important so you know what's happening.
Do you know the settings that reset the bypass mAh values in cell telemetry? I'm trying to disable it to get a good feel for what is actually being burned off.
