No, but in retrospect I should have. After reading Arthur Eld's postings on helicoils, I realized that a) the tapped holes on the cells were even less deep than I thought, b) using drill bits and taps that were tapered made them shallower. The first terminal I did I ended up snipping off a part of the helicoil that extended above the holes surface due to this. The resulting thread did torque to specs and is holding. Taht said, on the second terminal of that same cell I measure the length of the screw thread of the bolts provided with the cells and drilled carefully down to that depth before inserting the second helicoil - something I would not have even considered had this cell not be quite damaged already during shipping.
Meaning that a standard 1/4” drill bit allowed you to drill down 5mm without piercing the bottom of the cell?
What about the stock Helicoil Tap? We’re you able to use a stock Helicoil Tap without modification and did it allow you to tap a full 5 threads without piercing the bottom of the cell?
If so, I’d be very interested to see a picture of the stock Helicoil tap (and/or stock Helicoil kit) you used - if there is any way to avoid grinding bits and taps for an acceptable solution (~45 inch-lbs of torque), that would be a major simplification...
How many 1mm threads do you believe you have tapped and what level of inch-lbs have you torqued the repaired terminals to?The resulting thread/helicoil process went fine and holds great - and it didn't appear I got anywhere near going trhough the terimnal into the cell itself.
Also, did you use a drill press to drill your holes?
And finally, for this second terminal, did you also need to trim the Helicoil before inserting or were you able to use a stock Helicoil without modification?
