LukeL
Hey all! I’m 15 days into running my home off my new lifeo4 banks I purchased from Docan. We’ve lived Offgrid for 7 years. New batteries.
Using the JK B5A25S60P BMS (in case anyone else has) 1 requires 3 separate contactors TE 500 A.
Batteries are CATL 3.2v 280 ah. 16 per bank.
1. Background. When I paralleled the two 48v banks I ended up bulging 1 cell on bank A (cell 16 - positive terminal contact point for charging/inverting) and killing same cell on bank B (16b I call it - again positive side contact point). These cells both holding a charge now but I’m not using and scared of the bulges one.
My bad, I didn’t parallel at proper point. Docan great sending two replacements (I pay one, they pay other and freight covered). Impressed.
2. Currently running on 1 bank only until replacements arrive. Just the other day I killed cell 16 again (positive terminal that connects bank to inverter/charging system). Had no charge at all and will not take a charge at all. Totally dead. So I suspect I have a wiring problem that I’m not seeing. OR these cells just aren’t made to have that much current going through?! Which I doubt. They are far less robust than my monster lead acid batteries. Here is a picture of the 16th cell placement and that it keeps getting fried. Please excuse the rats nest. Need to iron the wrinkles before I tidy it up.
Here’s a picture of the BMS screen on 1 bank and it all appears to be working:
3. Specific to how I wired this BMS and the contacts - is it possible this my issue? Specifically where I connected all the contactors on their negative terminals. Will also show diagram:
4. These seplos battery box kits. Would that ensure not one cell is getting so much current through it?
Anyway just hoping a fresh set of experienced eyes might see why I keep having issues on that last cell on the bank. Or have insights.
Thank you kindly in advance.
Luke
Luke
