This will be dual purpose setup to run a ChangeMoore 12v fridge/freezer when traveling or to power a 110v house fridge when the power goes out.
I bought a Licitti 1000w and I missed the 100 watt limit on solar.
I also have a Dr. Prepare 100amp battery with the hub to play around with and I just ran a test with my
ChangeMoore fridge/freezer (with the add in tiny battery) and it ran at -4/37df for 2.5 days just on the battery alone which is great and had half life left on the internal battery.
Testing the Changemoore with an EB70s showed that a 200 watt panel will pretty much keep up with the ChangeMoore during most mixed weather and that a 100 watt panel will not in the same conditions.
The Licitti 1000w is rated for 100-200 amp battery according to the literature.
I was thinking to setup 4 280 amp prismatic cells in the Licitti (I think they will fit) and replace the SCC with a 40 amp SCC and wiring so I can use 2 200 watt solar panels.
Guess I would need to replace the inverter too.
My thinking is, by the time I am through, I will probably end up gutting the Licitti except for the simple things like 12v outlets and USB etc.
What say ye?
What say ye?
