I've been looking around for a FET based BMS solution to monitor parallel packs and has WiFi connectivity or can be connect to an Android Device / Raspberry Pi ( via USB ).
So far I've come across 1. Seplos BMS but appears that it can only be connected to PC and 2. Batrium but this is not FET based and therefore cannot shut-off the battery in a over-discharge over-voltage low-voltage situation.
Thanks for the feedback.
